Lives in: Paris, Île-de-France, FR
Using: SPARK-16 , WHISPERER-2
Questions
New whisperer
48
Updated at 2026-03-03 08:20:29 UTC
Topic: Connected Home
Bought a new whisperer as an old one is no longer working.
REMARK : WHILE I LIVE IN A TEMPERATE AREA NONE OF MY WHISPERERS LASTS MORE THAN 26 MONTHS WHICH IS SURPRISING AS IT IS NOT SUPPOSED TO BE A CONSUMABLE.
Clicked as required first blinking blue light then blinking white light.
Went to sensors and see the dead old one, the working one but do not see the newly bought one.
Do not see either a + sign to add a new one.
What should I do ?
Old whisperer
48
Updated at 2026-01-20 10:38:33 UTC
Topic: Troubleshooting
Seems a communication problem
New Whispere
48
Updated at 2025-03-31 21:05:02 UTC
What should I do ?
Red dot
48
Updated at 2024-07-03 18:53:21 UTC
What is the significance of a red dot next to the green bell ?
Do not see anything anywhere and have not received any notice.
Whisperer light
48
Updated at 2023-02-01 09:56:18 UTC
What should I do ?
Defective Whisperer
48
Updated at 2022-11-26 10:04:00 UTC
48
Updated at 2022-10-20 14:57:19 UTC
Thanks for your advice
Whisperer blank
48
Updated at 2022-08-16 07:24:14 UTC
No light on the device.
Discover/Irrigation
48
Updated at 2022-06-17 07:20:57 UTC
Discover irrigation
48
Updated at 2022-05-25 06:52:34 UTC
Watering days
48
Updated at 2022-04-16 18:22:19 UTC
Home display is correct and shows Last watering the day before at the date and time in the program (watering planned everyday) but under Discover many days are shown as if there has not been any irrigation.
What could be the reason why ?
Home page
48
Updated at 2021-11-04 12:39:30 UTC
Nothing changed
Whisperer connexion
48
Updated at 2021-05-19 14:52:55 UTC
Topic: Netro App
