Jim Simmons
Broomfield, CO, US
SPARK-16
Comments 1
Questions
2 Spark 16s linked?
Jim Simmons
Updated at
2022-06-22 14:56:08 UTC
Topic:
I've installed 2 Spark 16s to control a 26 valve system. All the valves are working fine with this setup. Are there instructions for the best way to configure this? I have low water pressure and can't run 2 valves at the same time, so some synchronization between the 2 Sparks is needed. I could manually setup restrictions on each unit, so they can't overlap, but that seems too coarse. Any ideas about the best way to program this?
