Maximum wire distance between controller and valves
更新时间 2021-01-16 14:20:49 UTC
Below is a chart indicating the maximum wire runs that can be used when installing AC solenoids and valves.
22 AWG: 600 feet
20 AWG: 700 feet
18 AWG : 850 feet
16 AWG: 1300 feet
14 AWG: 2000 feet
浏览: 10216   评论: 0
Addiel Isaac Moldes
更新时间 2020-07-19 11:43:54 UTC
浏览: 10387   评论: 2
Installed perfectly
Lakeside Gardens
更新时间 2020-07-12 14:57:53 UTC
And we are off and running.   Whisper went in the ground and started reporting right away.  Would be nice to connect it to my Ambient weather station as well.
浏览: 11217   评论: 1
更新时间 2020-06-22 07:37:55 UTC
浏览: 13390   评论: 6
Nuova interfaccia penosa!!
Andrea DiPi
更新时间 2021-11-05 03:00:01 UTC
浏览: 12701   评论: 1
Server upgrade scheduled on May 16th between 8:30PM and 9:00PM (Pacific Time)
更新时间 2020-05-17 03:23:28 UTC
To all Netro customers:
Due to rapid increase of active devices connected to the Netro cloud server, we are going to upgrade our server on May 16th Saturday night from 8:30PM to 9:00PM (Pacific Time). During that time frame, all cloud service will be temporarily unavailable but your watering schedules will run normally. If you have a smart watering controller, the light on the unit will blink fast.
浏览: 12369   评论: 0
alnavasa
更新时间 2020-05-08 20:36:44 UTC
Start ar 21:00 end at 3am
浏览: 11037   评论: 0
Fertilization program
Andrea Merito
更新时间 2020-04-27 14:30:47 UTC
Best.
Andrea
浏览: 10539   评论: 1
Netro now supports Spanish, Italian, French and German for Amazon Alexa
更新时间 2020-03-16 02:40:52 UTC
Great news! We now support Spanish, Italian, French and German for Amazon Alexa voice control. Please find the new skill "NetroHome" in your Alexa app and link your Netro account.
In case you experience difficulties in using the NetroHome skill, please write to support@netrohome.com or contact us in the Netro app.
浏览: 32146   评论: 7
更新时间 2020-02-28 07:49:20 UTC
浏览: 11819   评论: 3
How to replace an old controller with more than 12 zones
更新时间 2019-11-06 09:20:19 UTC
If your old controller has more than 12 zones, you will need to have 2 Netro controllers to replace it. Please follow the diagram below to safely wire the 2 controllers:
Now you can use the 2 C slots for the common wires and the 2 sets of 1-12 slots for the zone wires. If you do not have a master valve or pump, just ignore the orange wires.
IMPORTANT: the blue wire has to be connected to the left 24VAC on both controllers and the yellow wire has to be connected to the right 24VAC on both controllers.
Please contact us if you need the wire connectors shown in the picture.
浏览: 11894   评论: 0
更新时间 2019-12-25 01:46:02 UTC
To the Netro Community,
浏览: 14741   评论: 0
