Actualizado 2022-07-02 17:31:23 UTC
Ver: 7396   Respuesta: 1
Login Error: Can't find user
Patbouvry
Actualizado 2022-07-04 01:08:57 UTC
Pat.
Ver: 7203   Respuesta: 1
eater flow meter
Corneliu PINTILIE
Actualizado 2022-07-05 14:11:11 UTC
Ver: 7860   Respuesta: 1
Home51
Actualizado 2022-07-05 20:23:39 UTC
Zev
Ver: 7640   Respuesta: 1
Laks
Actualizado 2022-07-06 13:33:47 UTC
thank you
Ver: 7924   Respuesta: 1
Manual runs overriding schedule
unislock
Actualizado 2022-07-07 12:02:15 UTC
Is there a way to not have manual runs conflict with the smart schedule?  At times I turn sprinklers on for kids to have fun or to test a newly installed head for a few minutes. These manual runs (even for a minute or two) in these zones are not being run during the next scheduled run. This is frustrating and now I need to do a lot of manual runs to ensure lawn gets appropriate amount of water and is basically taking away my ability to auto schedule.
Thoughts?
Ver: 8812   Respuesta: 2
Smart watering settings
SK Breuer
Actualizado 2022-07-07 17:34:52 UTC
Ver: 7940   Respuesta: 1
Zones cut out
tbbucans
Actualizado 2022-07-08 00:44:31 UTC
Ver: 6428   Respuesta: 1
Frank Fang
Actualizado 2022-07-08 18:44:28 UTC
Ver: 6510   Respuesta: 1
WU weather provider question
Weston Hull
Actualizado 2022-07-09 01:43:02 UTC
Ver: 8020   Respuesta: 1
Want to use two controllers
dl74pw@yahoo.com
Actualizado 2022-07-09 14:19:31 UTC
Ver: 6402   Respuesta: 1
Power device heat
David Domingues
Actualizado 2022-07-09 17:15:45 UTC
Hello all,
I just bought a Netro controller with only 2 areas setup and I like it so far.
I was wondering if the noise and heat from the power supply was a  normal thing to happen.
Thanks in advance.
Ver: 9069   Respuesta: 2
Actualizado 2022-07-10 11:25:02 UTC
Ver: 8414   Respuesta: 1
Day view
Actualizado 2022-07-12 04:10:37 UTC
Ver: 8302   Respuesta: 1
Netro connection to IFTTT
Sarah Kottke
Actualizado 2022-07-12 13:44:09 UTC
Anyone had luck?
Sarah
Ver: 8353   Respuesta: 1
More data
Jim Shaffer
Actualizado 2022-07-13 13:06:30 UTC
Ver: 8171   Respuesta: 1
Plant sensor
Miro D
Actualizado 2022-07-14 10:42:35 UTC
Ver: 8167   Respuesta: 1
Waters excessively
Cindy Luvender
Actualizado 2022-07-14 16:38:38 UTC
Ver: 8524   Respuesta: 1
Pixie water pressure
Chris
Actualizado 2022-07-15 09:03:05 UTC
Ver: 8079   Respuesta: 1
Actualizado 2022-07-15 12:27:12 UTC
Ver: 9068   Respuesta: 2
