Where do I have to install the whisper sensor?
Paolo1968
Actualizado 2021-05-11 09:46:31 UTC
I have recently bought  a whisper sensor to complement my Netro watering system. I have a watering system in the garden, where Can I install the whisper in order to avoid it will be wet all days by the watering system? Do I have to put it outside of the garden? Thanks. Paul
Ver: 9102   Respuesta: 2
Whisperer stop working
Gianluca De Virgilio
Actualizado 2021-05-11 15:34:15 UTC
Ideas?
Ver: 7196   Respuesta: 1
Smart water regulation
Albert Heinold
Actualizado 2021-05-13 09:40:49 UTC
Thanks for any help.
Ver: 6717   Respuesta: 1
Whisper Pairing
Sang Peiris
Actualizado 2021-05-13 12:11:59 UTC
Hello-  I have two new whisper devices. Both will not go into pairing mode.  Press power button six times and the light just blinks red on and quickly off. Press three times and same thing.
How do I get the whisper into pairing mode?
Ver: 8504   Respuesta: 1
Rainfall from weather station
Actualizado 2021-05-14 16:50:13 UTC
Ver: 8475   Respuesta: 1
John Lillistone
Actualizado 2021-05-15 09:23:08 UTC
Any ideas anyone?
Ver: 8154   Respuesta: 2
Watarering modes
Actualizado 2021-05-16 07:44:57 UTC
Hi there
Ver: 8956   Respuesta: 2
Seed watering
Adrian Azzopardi
Actualizado 2021-05-16 10:18:05 UTC
Ver: 6959   Respuesta: 1
Turning off wayer
Actualizado 2021-05-16 21:29:12 UTC
Ver: 7647   Respuesta: 2
Programs Setup
fernando colon
Actualizado 2021-05-18 04:44:56 UTC
I have 5 zones programmed daily in 15/20/35 mins intervals however when I goto the home screen I see them all in 15mins intervals... Seems as the home screen bypass' the current daily programmed schedule.  How do I have my programs run as intended 15/20/35 .ins intervals vs the 15mins it self imposed?
Ver: 8836   Respuesta: 1
Whisperer connexion
Actualizado 2021-05-19 14:52:55 UTC
Ver: 8111   Respuesta: 2
amagalla
Actualizado 2021-05-19 16:45:52 UTC
Edit:
The app on my tablet shows:
Server Status:    OK
Response time:  0.3 s
Ver: 8027   Respuesta: 2
bad wireless?
amagalla
Actualizado 2021-05-19 16:50:44 UTC
Tony
Ver: 7205   Respuesta: 1
Netro Pixie Timer
claudinne
Actualizado 2021-05-20 17:09:36 UTC
Ver: 8309   Respuesta: 1
Mitch Green
Actualizado 2021-05-20 22:11:37 UTC
Ver: 8637   Respuesta: 1
Learning
John Conley
Actualizado 2021-05-21 12:05:43 UTC
Ver: 8095   Respuesta: 1
Sensor usage
Ilya Lifshits
Actualizado 2021-05-22 08:17:29 UTC
Hi ,
Ilya
Ver: 8247   Respuesta: 1
Brad Grizzly
Actualizado 2021-05-23 03:42:20 UTC
Ver: 6651   Respuesta: 1
Connect one whisperer to two pixies
jmkluft
Actualizado 2021-05-24 14:14:03 UTC
For the moment, I have one whisperer connected to one pixie, and everything is working fine.
I have a question though, if I would add another pixie to control another watering zone, can I connect the same whisperer to that second pixie?
In other words, can I connect one whisperer to two pixies?
Thx,
JM
Ver: 8421   Respuesta: 1
banaszar
Actualizado 2021-05-25 17:23:58 UTC
Ver: 6746   Respuesta: 2
