Tony Pellegrino
Actualizado 2021-04-13 19:14:36 UTC
Ver: 8271   Respuesta: 1
Fabio Pellizzoni
Actualizado 2021-04-13 20:10:43 UTC
Do you have any idea why ?
Ver: 6986   Respuesta: 1
How to Set Schedule?
tonycurry
Actualizado 2021-04-14 02:13:12 UTC
Ver: 6970   Respuesta: 1
Manual start on demand
Krzysztof Wiater
Actualizado 2021-04-14 03:34:58 UTC
I just got unit garden hose pixie unit. I am looking for a manual watering on demand button. I want to be able to turn it on and off an needed. Right now i see I have to wait 1 hr or so to turn it on. Am I missing something here? Please help. Thanks in advance.
Ver: 8481   Respuesta: 1
Time zone not supported
Havre de Grace
Actualizado 2021-04-15 08:11:30 UTC
I keep getting this error when I try to put my address in Jersey, Channel Islands.
Ver: 6575   Respuesta: 1
How to delete a device
Carles
Actualizado 2021-04-16 12:33:31 UTC
Ver: 7193   Respuesta: 1
Multiple Pixies?
J Forrest
Actualizado 2021-04-17 03:33:18 UTC
Ver: 6857   Respuesta: 1
Whisperer sensor soil type
Aki Lan
Actualizado 2021-04-17 13:47:25 UTC
Is whisperer sensor able to know your soil type due to drain capacity?
Ver: 8280   Respuesta: 1
dougbrandes
Actualizado 2021-04-19 10:06:30 UTC
Ver: 6843   Respuesta: 1
Email address
Troy pascoe st
Actualizado 2021-04-19 11:01:30 UTC
Ver: 6795   Respuesta: 1
Michael Sheahan
Actualizado 2021-04-19 21:19:54 UTC
Ver: 8149   Respuesta: 1
Mitch Green
Actualizado 2021-04-20 00:44:59 UTC
Ver: 7715   Respuesta: 1
Jason
Actualizado 2021-04-20 21:49:32 UTC
Ver: 6582   Respuesta: 1
Weather data
Vardhan Rajkumar
Actualizado 2021-04-21 18:03:34 UTC
Vardhan
Ver: 8793   Respuesta: 1
Zones
dougbrandes
Actualizado 2021-04-22 12:34:57 UTC
I only have 2 zones.  1st zone is programmed for only 2 days per week while the 2nd zone is programmed everyday and at a different time then the first zone.  However on the 2 days the first zone comes on, the second zone does not despite be programmed to.  As mentioned the on times are completely different.
Ver: 6678   Respuesta: 1
Trigger a single zone based on zwave switch
Moe E
Actualizado 2021-04-22 14:54:46 UTC
My pools water fill line is connected as a zone on my sprinkler system. I would like to trigger turning on and off a zone based on a zwave switch status. Can this be done, or should I return my netro for a different system? It looks like netro does not have api access, and IFTTT is extremely limited. Thanks
Ver: 6817   Respuesta: 1
LAWN
Actualizado 2021-04-23 23:08:09 UTC
Set up wifi
Neti URC - 87B (ok saved)
home netwok connected.
Ver: 6895   Respuesta: 1
Open tel zones atbthe same time
ivan hernandez
Actualizado 2021-04-25 11:58:25 UTC
I have to activate two zones at the same time but i dont know how to do It.
Ver: 8126   Respuesta: 1
Can not connect to wifi
Andrei Stancovici
Actualizado 2021-04-25 18:30:25 UTC
Hello. I have restarted my netro 16 after winter. First it connected ok and after a power lose i stopped connecting to wifi. I have tried everything. The light is solid as if is connected. Plese help. Thank you
Ver: 6597   Respuesta: 1
Netro app discover tab
Zee D
Actualizado 2021-04-25 20:52:09 UTC
Ver: 6704   Respuesta: 1
