Kevin Westling
Actualizado 2021-03-28 06:40:48 UTC
Ver: 7375   Respuesta: 1
Actualizado 2021-03-29 08:57:05 UTC
I have checked in the smart schedule that tomorrow is programmed to run zones that should be skipped.
I have set up the whisperer to skip run if moisture is above 40%. Current moisture is:
  • Zone 2 - 92%
  • Zone 5 - 70%
Ver: 7919   Respuesta: 2
Server offline
Mirko Paganelli
Actualizado 2021-03-30 16:15:01 UTC
Ver: 7550   Respuesta: 1
What do the icons mean?
Jim Stichbury
Actualizado 2021-03-31 06:55:06 UTC
Ver: 7156   Respuesta: 1
Firmware update
Francesco Angelone
Actualizado 2021-04-01 13:33:34 UTC
my firmware version is the 1.1.1
Please, can I have the last firmware vesion and the instructions for update my controller.
The serial number is E4956E4B6B05
Ver: 8931   Respuesta: 1
Light flashing
lightnin
Actualizado 2021-04-01 19:11:23 UTC
Why is my light flashing on my Netro?
Ver: 8483   Respuesta: 2
Instant watering
hermanins@gmail.com
Actualizado 2021-04-03 00:01:28 UTC
Ver: 6983   Respuesta: 1
Many inexplicable Manual runs
Panos Charalambopoulos
Actualizado 2021-04-03 11:37:15 UTC
Hello everyone ,
Ver: 8639   Respuesta: 1
Does the Pixle have to be installed with the water coming into it on the "Hose Faucet Connection" side?
Austin Franklin
Actualizado 2021-04-03 19:04:13 UTC
Basically, is the Pixie water control valve one way, or can it shut off/turn on with pressure from either side?  In order to install it so the button faces up, I need to install it so the water comes in what is labeled as the "Outlet" side.  I don't know if it's labeled "Outlet" because it is a male connection, or because it cares about the direction of the water.  Otherwise, I will need to buy a male/male and female/female adapter, flip it "upside down" and use it with the button facing down.
Ver: 8420   Respuesta: 1
Can’t start Netro
Joe Horner
Actualizado 2021-04-05 14:47:49 UTC
I have a good WiFi signal.
Ver: 6967   Respuesta: 1
jjmengibar
Actualizado 2021-04-05 18:16:46 UTC
How can I reset any zone
Ver: 7772   Respuesta: 1
jjmengibar
Actualizado 2021-04-05 18:19:11 UTC
Ver: 9277   Respuesta: 1
David Farries
Actualizado 2021-04-07 02:16:14 UTC
Ver: 7279   Respuesta: 1
Abel Vargas
Actualizado 2021-04-09 00:49:42 UTC
Ver: 11861   Respuesta: 1
Adding multiple sensors to a Pixie
phatd
Actualizado 2021-04-09 18:13:11 UTC
I have a mister setup with multiple Herb racks and raised garden beds. I just got a Pixie and a few Whispers. My hope was using one Pixie and monitoring each bed with a whisper. Is this possible? Can I create multiple zones? Is this something going forward that might be possible? I don't want to set them up as standalones.
Ver: 8529   Respuesta: 1
Moisture Level
Des Mullin
Actualizado 2021-04-09 23:48:09 UTC
Ver: 7643   Respuesta: 1
Disable a zone
fernando colon
Actualizado 2021-04-10 14:15:21 UTC
Ver: 11773   Respuesta: 1
How to delete a device
Scott Gustafson
Actualizado 2021-04-10 16:04:18 UTC
Scott
Ver: 7832   Respuesta: 1
Timezone not supported
Shai Amiel
Actualizado 2021-04-11 19:33:24 UTC
why do i get this error? I am trying to install in israel
Ver: 8661   Respuesta: 1
Imran Ali
Actualizado 2021-04-12 22:54:05 UTC
Imran Ali
Ver: 7484   Respuesta: 1
