Not skipping raining days
Felipe VNunes
更新時間 2026-04-17 23:00:44 UTC
Hi guys,
My Netro system is not skipping watering on rainy days. As shown below, it still watered even though it is configured to skip the previous day, the rainy day itself, and the day after. Any recommendations?
瀏覽: 2866   回覆: 1
enable switch
Andrew McNaughtan
更新時間 2026-04-19 22:32:06 UTC
I switched the enable switch in the Netro app to disable and now I can't get it to turn back on. The app says "next run not scheduled". When I close the app and reopen it, the switch has moved back to the disabled position. Nothing works, I can't even manually water. The controller has a green light showing and I have tried powering the controller off and back on and it reconnects without an issue but the app will not work.
瀏覽: 2920   回覆: 1
Different weather and does not skip rainy days
Leonardo A
更新時間 2026-04-20 06:25:01 UTC
Good morning, if anyone can help me, I have two Netro control units installed 1 km from each other and they give me two different forecasts, both having the same weather portal, one irrigates it even with rainy days, while the other gives me the programming in 20 days.....
瀏覽: 3322   回覆: 1
When Zone 11 is programmed to run but zone 4 runs instead.
Mike
更新時間 2026-04-21 18:10:56 UTC
Zone 4 correctly runs when zone 4 is activated
瀏覽: 2902   回覆: 1
Feature Request / Setup Assistance: Apply Rain Skip to User Programs without Smart Scheduling
Alessandro Zannini
更新時間 2026-05-01 16:47:43 UTC
Hello Netro Support Team,
I am a user of the Netro system and I need assistance with my zone configuration.
Currently, I have a specific zone (named "Goccia") set up with a User Program (fixed days and fixed minutes). I do not want the Netro AI to change my watering duration or frequency.
However, I want the system to automatically skip my fixed program if it rains or if rain is predicted.
In my app settings for this zone, I see that "Smart Zone" is currently Disabled. My questions are:
1. If I enable "Smart Zone", will it overwrite my manual minutes and days, or will it only apply the "Rain Skip" feature to my existing User Program?
2. How can I ensure that the system follows my fixed schedule strictly, but still uses weather data to skip cycles during rain?
I want my manual program to be "Weather-aware" without becoming "AI-controlled".
Thank you for your help.
Best regards,
瀏覽: 2346   回覆: 1
Notifications sur Android
Cyrille ROBINET
更新時間 2026-05-03 16:14:14 UTC
Bonjour,
J'aimerais avoir de l'aide.
Merci
瀏覽: 2342   回覆: 1
programs - reordering
Lee Hill
更新時間 2026-05-08 06:40:14 UTC
瀏覽: 2280   回覆: 1
programs - status sign
Lee Hill
更新時間 2026-05-08 06:45:32 UTC
Developers, can you add some indication to list of programs to see which is enabled, which is not?
Instead of going into each and scroll to the very bottom to check 'enabled'.
I think of either being grayed out or adding a sign, whatever simplest may work.
thank you
瀏覽: 2230   回覆: 1
New feature request
更新時間 2026-05-10 19:34:04 UTC
瀏覽: 2256   回覆: 1
My password
Cliff Howatd
更新時間 2026-05-11 14:08:56 UTC
My password keeps dropping, and I have to re-enter the password every time I want to use my phone to access programs.
瀏覽: 2250   回覆: 1
Sensores fallan
Juan Pascual
更新時間 2026-05-12 13:01:26 UTC
Todos los sensores que he adquirido al cabo de dos años dejan de cargarse por el panel solar y son inservibles
Conectados por usb a una fuente de alimentación son capaz de emparejarse pero al desconectarse dejan de funcionar
Enchufados a la corriente la luz única un bucle de rojo de menos a más parpadeo amarillo y parpadeo verde. Los puedo dejar cargando por usb 12 horas pero al desconectarlo se mueren
Alguna solución ?
瀏覽: 2256   回覆: 1
Zones not running
Richard Snyder
更新時間 2026-05-14 13:48:46 UTC
All zones are programmed to run but only zone 1 runs.
瀏覽: 2214   回覆: 2
Why would it show rain on the Home Screen when there is none in the forecast
Michael Harrington
更新時間 2026-05-16 01:39:35 UTC
瀏覽: 2220   回覆: 1
Longer watering per zone
Ruud
更新時間 2026-05-16 21:17:27 UTC
I have a Netro Sprite (6 zones).
I would like to water one time a week, 4 hours per zone in one run. I am not able to make programmes and single runs longer than 60 minutes.
Am I doing something wrong, or is this not supported?
Thanks for helping me out.
瀏覽: 2186   回覆: 2
Riego manual
Javier Galván Romo
更新時間 2026-05-18 11:15:08 UTC
¿Como puedo hacer un riego manual zona a zona para comprobar lis goteros obstruidos?
瀏覽: 2475   回覆: 1
Changing WiFi Network post original installation
deleted_20260518221841_george
更新時間 2026-05-18 14:03:27 UTC
Hi- been using your sprinkler controller for several years and have recently added a new WiFi network.
I'm following the instructions how to switch the Netro controller to a new WiFi network. After resetting the controller, it change my iphone WiFi network over to Netro-XXX (which tells me I have no internet access).
When I return to the Netro app and click 'Next', it just keeps instructing me to connect to Netro-XXX first.
The Netro controller continues to blink despite unplugging it so stuck in limbo now.
瀏覽: 2178   回覆: 2
Change Wi-Fi connection
Ruth Wengert
更新時間 2026-05-20 03:18:14 UTC
I have changed the name of my Wi-Fi. I need to change my Wi-Fi connection to its new name
瀏覽: 2129   回覆: 1
Ruth Wengert
更新時間 2026-05-20 03:19:27 UTC
I have changed the name of my Wi-Fi. I need to change my Wi-Fi connection to its new name I have a new Wi-Fi in your hub will not work because it can’t download a new Wi-Fi for some damn reason
瀏覽: 2158   回覆: 0
Ruth Wengert
更新時間 2026-05-20 03:19:34 UTC
瀏覽: 2305   回覆: 2
Greenhouse zone
Ivan G
更新時間 2026-05-20 08:59:47 UTC
瀏覽: 3608   回覆: 1
