Will
更新時間 2026-01-27 03:13:26 UTC
瀏覽: 3682   回覆: 1
cpline
更新時間 2026-02-02 17:04:38 UTC
瀏覽: 3675   回覆: 1
Notification
Alexis Demosthenous
更新時間 2026-02-05 19:28:19 UTC
瀏覽: 3727   回覆: 1
Will
更新時間 2026-03-17 21:54:57 UTC
瀏覽: 4379   回覆: 3
Sensor to zone
Mark Zeck
更新時間 2026-02-05 23:17:03 UTC
How do I connect my sensors to zones? I have the latest.
瀏覽: 3751   回覆: 1
Feature Request
John Sirois
更新時間 2026-02-10 05:56:14 UTC
John
瀏覽: 3548   回覆: 1
Supported Hardware
Colin Brierley
更新時間 2026-02-12 06:13:48 UTC
瀏覽: 4026   回覆: 1
Support email- No reply
更新時間 2026-02-21 16:06:19 UTC
瀏覽: 3836   回覆: 2
RKR Home
更新時間 2026-03-03 03:32:35 UTC
瀏覽: 3658   回覆: 1
New whisperer
更新時間 2026-03-03 08:20:29 UTC
Bought a new whisperer as an old one is no longer working.
REMARK : WHILE I LIVE IN A TEMPERATE AREA NONE OF MY WHISPERERS LASTS MORE THAN 26 MONTHS WHICH IS SURPRISING AS IT IS NOT SUPPOSED TO BE A CONSUMABLE.
Clicked as required first blinking blue light then blinking white light.
Went to sensors and see the dead old one, the working one but do not see the newly bought one.
Do not see either a + sign to add a new one.
What should I do ?
瀏覽: 3615   回覆: 1
Monkeyzu
更新時間 2026-03-12 08:20:45 UTC
瀏覽: 3593   回覆: 1
Seeding mode
John Sirois
更新時間 2026-03-15 04:23:37 UTC
瀏覽: 3636   回覆: 1
Adding a 2nd system
Jayden Lockley
更新時間 2026-03-21 07:03:33 UTC
I currently have a Netro Sprite system set up on a bore, I'm only using 9 stations currently but I can't easily add any more stations/wiring to this system.
I can easily access the wiring where I would like to add more stations, am I able to pick up the earth and pump start wires, and add a 2nd sprite or spark controller there?
Or has anyone got any ideas of how I can add more stations without running more wiring back to the master controller?
瀏覽: 3670   回覆: 1
Drip
Tim P
更新時間 2026-03-22 18:03:43 UTC
All the zones work except I do not have any water coming out of the drip heads
瀏覽: 3315   回覆: 1
Drip
Tim P
更新時間 2026-03-22 18:03:51 UTC
瀏覽: 3345   回覆: 1
Drip
Tim P
更新時間 2026-03-22 18:23:10 UTC
瀏覽: 3303   回覆: 1
Pixie se desconecta
Lino
更新時間 2026-03-22 19:30:16 UTC
Por qué se desconecta después de unos minutos mi unidad Pixie si tiene batería?
瀏覽: 3417   回覆: 1
Combine 2 zones
Alexis Demosthenous
更新時間 2026-04-07 03:33:14 UTC
Hello everyone,
For my lawn i have 2 watering zones, is there a way to "force" schedule to combine those 2 zones to always follow each other? I dont want to water half my lawn on Monday and the other half on Thursday.
瀏覽: 3344   回覆: 2
Any way for user to open and replace battery in Whisperer 2?
更新時間 2026-04-09 02:24:02 UTC
Any way for end user to open and replace battery on a whisperer 2?  It is out of warranty.
瀏覽: 3381   回覆: 1
Multiple locations
paul.robinson@bigbend.net
更新時間 2026-04-12 21:06:55 UTC
瀏覽: 3310   回覆: 1
