Candice Wang
更新时间 2026-08-06 07:50:00 UTC
Dear Netro Community,
What We Are Doing
📧 support@netrohome.com
Best regards,
Netro Support Team
浏览: 8295   评论: 0
Nigel Briggs
更新时间 2025-01-15 10:05:07 UTC
Why ?
浏览: 10736   回复: 1
Sensori funziona anomala
Mattia Forti
更新时间 2024-06-03 07:45:35 UTC
Ho un sensore che funziona male, non legge la temperatura e la lettura del umidità è un altalena.
Come posso risolvere? Inoltre rileva umidità 25% e sta piovendo abbondantemente da più di 2 ore.
浏览: 10501   回复: 2
Pixie z1 - smart scheduling for vegetable garden
Jamie J
更新时间 2024-05-15 14:47:14 UTC
Hello!
We just planted a raised bed vegetable garden with a variety of fruits and vegetables (zucchini, yellow squash, cucumber, green beans, strawberries, 2x blueberry bushes) and I bought the Pixie Z1 to use with a soaker hose setup.
I just setup the pixie and discovered the smart watering options do not include any of these plants.
Does anyone have successful recommendations for settings that would be best for a vegetable garden?
浏览: 9453   回复: 0
Recommend watering schedule
Carolyn Simmons
更新时间 2024-03-17 23:35:07 UTC
We are in zone 9 in Conroe, Texas and would love knowledge on best length of time to water and how often!  Recommendations please!
浏览: 10089   回复: 1
Starting new garden from scratch
Cori
更新时间 2024-03-06 03:16:19 UTC
Hello!
Everything is setup to sow our 170m2 of grass this weekend.
All local gardeners told me to irriigate the planted seeds 5min during the morning and 5min during the night, everyday, however the Netro smart program sets up a weird combination of 10min at 6am then 10 min at 6:40am, and then also for instance 2 days off (each phase, we have 3 for the grass), and this is choosing 'new plant' option.
  Should we leave the Netro smart program or Should we choose our own one???
Thanks!!
浏览: 10142   回复: 1
Good results
R C
更新时间 2023-10-24 18:55:29 UTC
浏览: 12228   评论: 2
Luis T
更新时间 2023-06-18 15:30:17 UTC
Any comments are welcome.
浏览: 10865   回复: 3
S R
更新时间 2023-05-13 00:02:22 UTC
浏览: 12146   回复: 2
Intelligent mode useless
Juan Lambea
更新时间 2023-04-14 15:51:37 UTC
浏览: 10645   回复: 1
carlos davalos melgar
更新时间 2023-04-13 20:07:05 UTC
浏览: 10058   回复: 1
更新时间 2023-04-13 20:06:57 UTC
浏览: 10246   回复: 0
Alessandro Alfei
更新时间 2022-11-11 23:11:30 UTC
Ciao, una domanda.
浏览: 11258   回复: 1
Soil
Stephen Brewer
更新时间 2022-08-27 12:11:15 UTC
Many thanks in advance
浏览: 10936   回复: 1
Jorge Izquierdo
更新时间 2022-08-11 10:31:39 UTC
Regards!
浏览: 10622   回复: 1
Rocky Hill
更新时间 2021-07-05 12:35:21 UTC
  • Tomatoes;
浏览: 13827   回复: 2
BOB COOPER
更新时间 2021-06-20 16:40:50 UTC
浏览: 11222   回复: 1
Abel Vargas
更新时间 2021-04-09 00:49:42 UTC
浏览: 11291   回复: 1
Ideal Soil Moisture
Mike Biondo
更新时间 2021-03-26 01:51:09 UTC
What is an ideal soil moisture level? My new Netro Whisper is measuring 83% down from 88% 3 hours ago. Is this too moist? It is average raised bed plant soil. I have googled and found some sites saying no more than 45% and some sites say no less than 70% so I am very confused!
浏览: 11439   回复: 1
Moisture and light range
Don Lewandowski
更新时间 2020-12-31 21:46:19 UTC
浏览: 11230   回复: 1
