Smart watering
Alejandro Foubelo
Actualizado 2020-08-07 01:27:29 UTC
Hello, I set the app to run 3 manual programs on the odds day and I have the smart watering system active on all zones.
Will it skip my watering if there is rain in the forecast on an odd day?
Ver: 7627   Respuesta: 1
Moisture level for lawn
Jan
Actualizado 2020-08-08 08:43:43 UTC
Dear community
Ver: 10591   Respuesta: 1
Sensor umidity
Andrea
Actualizado 2020-08-09 16:14:57 UTC
I have two sensors installed for a few days but the humidity still marks 98% why?
Ver: 8830   Respuesta: 1
Network error
Fre Camp
Actualizado 2020-08-11 22:36:39 UTC
No funcionan los aspersores
Ver: 7565   Respuesta: 2
Lost connection on holidays
lekter
Actualizado 2020-08-12 08:45:08 UTC
I'm on vacation and my internet connection has been cut off. I had planned before on netro waterings for the week. Is that without an internet connection in my house, the waterings programmed before will still be done?
Arnaud
Ver: 7813   Respuesta: 2
Battery not holding charge
Steve Walczak
Actualizado 2020-08-12 17:49:20 UTC
Ver: 8869   Respuesta: 2
No funciona
Fre Camp
Actualizado 2020-08-13 07:40:48 UTC
En la APP todo parece ir bien, pero no riega.
Ver: 8970   Respuesta: 2
What does this mean?
Bowie Xu
Actualizado 2020-08-16 16:58:18 UTC
Thanks in advance.
Bowie
Ver: 7918   Respuesta: 1
Unable to reset into Host mode to change WiFi setting
dabo
Actualizado 2020-08-16 17:29:54 UTC
I have a 6 zone Netro sprite and need to update my wifi settings. No matter what I do I'm unable to get the Netro to enter host mode. I've tried hitting the RST button numerous times before or after manual reboots (even waiting the full 3+ minutes after re-plugging the device in). I even tried a full manual reset by holding the RST button for 10 seconds and the device still doesn't reset. I'm starting to doubt whether the reset button on my device works.
Has any one had any similar problems or pointers for just getting the Netro to join a new WiFi network? I'd rather not do a full reset and lose my zone settings, but at this point I've even tried that and can't get that working.
Ver: 9113   Respuesta: 2
Arthur
Actualizado 2020-08-20 03:58:15 UTC
Ver: 7360   Respuesta: 1
Battery not charging
Petar Nedyalkov
Actualizado 2020-08-21 18:24:41 UTC
My solar powered controller doesn’t charge its battery - not sure if it’s a battery problem - the controller is under direct sunlight for at least 6 hours every day.
I’ve set it to water for 1 hour every day so it’s a simple On/Off once a day.
Have other people had this issue?
Ver: 9590   Respuesta: 2
Add manager
Fabio Pellizzoni
Actualizado 2020-08-27 08:26:50 UTC
Ver: 7439   Respuesta: 1
water connection of Pixie
graziani
Actualizado 2020-08-27 08:29:42 UTC
can you please confirm sizes of water connection, I don't find on the website
Ver: 8918   Respuesta: 1
What about your API ?
Actualizado 2020-08-29 17:19:23 UTC
Christophe
Ver: 8493   Respuesta: 2
Keeps watering even though it rains
Oleg Frayman
Actualizado 2020-09-02 01:51:56 UTC
My sprinklers keep watering even though skipping if it rains is selected with low threshhold
Ver: 7207   Respuesta: 1
Email too long in android app
Christoforos
Actualizado 2020-09-02 09:49:14 UTC
Ver: 7426   Respuesta: 1
Whisper sensor
Randle Griffin
Actualizado 2020-09-03 04:18:11 UTC
Ver: 7121   Respuesta: 1
Sensor watering adjustment doesn't work - bug
Roman Stanek
Actualizado 2020-09-04 04:49:34 UTC
I installed two sensors today and added watering adjustment so that every time the humidity goes below 10% another 10 minutes of watering is added. Unfortunately, there is a bug and the watering time is triggered right away even though the faucet timer connects only every three hours. The additional watering time needs to be scheduled after the next timer sync and not right away. It's a clear bug.
Ver: 7440   Respuesta: 1
controller kept go offline
Actualizado 2020-09-05 01:12:13 UTC
Hello, wondering why my watering controller kept going offline.  Once turning it off/on, it will goes online again but will go off in several hours later.  Is it time for me to get a new controller?  I hope not
Ver: 9857   Respuesta: 2
Remove Plant Sensor dropdown
Scott McKay
Actualizado 2020-09-05 21:09:40 UTC
Ver: 7156   Respuesta: 1
