Products
Smart Sprinkler Controller
Sprite
Spark
Smart Indoor Watering System
Stream
Smart Plant Sensor
Smart Hose Faucet Timer
Pixie Z1
Pixie
Pixie 2nd Gen
Smart Garden Light
Lapland S1
App
Accessories
Pixie, Smart Hose Faucet Timer (White, US)
List Price:
Price:
$89.00
You Save:
$30.00
Model:
Threads:
In Stock
Model: Pixie-1
Technical Specifications
– Dimensions: 6.5 X 4.3 X 1.9 (inches)
– Weight: 16 oz / 450 g
– Box contains: smart hose faucet timer, battery, water filter, charging cable, quick installation guide
– Operating temperature range: 32℉ to 122℉ / 0℃ to 50℃
– Water pressure: 0.02MPa to 0.8Mpa
– Threads: US standard 3/4” GHT (Garden Hose Thread)
Warranty
user_manual_pixie.pdf
It is 3/4” GHT (Garden Hose Thread).
WiFi Connection
Pixie needs Wi-Fi to connect to the internet. There are two frequency bands used for Wi-Fi communication: 2.4GHz and 5GHz. Most modern routers can broadcast on both bands. Pixie only uses the 2.4GHz band because the 2.4GHz has a farther range than the 5GHz. To make sure Pixie is within your Wi-Fi network’s range, the easiest way is to use your phone to test. If your phone is able to detect the WiFi signal, Pixie should be able to connect at the same location.
The timer will continue to execute the pre-loaded schedules for up to one month.
Mark Smith
Member since 2021-11-26
Overall rating: 5/5
2021-12-25 20:12:01 UTC
I have this setup in New Zealand and it works great. The only devise I could find that was 100 WiFi. Time to replace all my other timers.
Julian Demetz
Member since 2021-01-25
Overall rating: 1/5
2021-03-04 14:42:37 UTC
The Produkt is Not arrive the destination
