Accessories
Spark-8, Smart Watering Controller
List Price:
Price:
$149.00
You Save:
$30.00
Model:
Power Adapter:
In Stock
Mechanical Specifications
– Dimensions: 5.7 X 5.7 X 1.6 (inches)
– Weight: 12.7 oz / 360 g
– Output: 8 zones + 1 master valve
– Wire size: 18 AWG to 22 AWG
– Box contains: smart irrigation controller, AC adapter, wall screws, quick installation guide
Electrical Specifications
– AC Input: 24VAC, 50/60Hz, 800mA
– WiFi: 802.11 N, 2.4Ghz, EU
Warranty
user_manual_spark.pdf
Wi-Fi Connection
Cloud Services
Watering Schedules
Weather Data
Watering Regulations
Sensors
![17](/assets/17-0d393d43a52e40afe14e207fff18b31e3b0a22260734b015e5134b2d3970eb2e.png)
Giovanni Baroni
Member since 2023-03-20
Overall rating: 5/5
2023-07-11 13:44:45 UTC
Fully satisfied ! May be the weather forecast could be better
![4](/assets/4-73504871247ad4409a086a821ccd618af593e1ed3784afed41f9606146999b55.png)
panos
Member since 2021-01-18
Overall rating: 5/5
2021-04-27 13:21:49 UTC
Can't think of a better smart watering controller ! works flawlessly , setup is a breeze, stats provided are great, the community is amazing, works in Greece too. Can't rate highly enough!
![26](/assets/26-efcaf247b4327d5074b711b42380d19b346a95116e87f9e0253c6c10e5583b47.png)
Nicolás De las Heras Ortiz
Member since 2021-03-30
Overall rating: 5/5
2021-04-01 11:15:17 UTC
I request the cancellation of the order, according to the revived mail. in which I have been given a discount code indicating that I cancel and request again. Thanks a lot. You can confirm the process for me. Nicholas.
