Products
Pixie Z1, Smart Hose Faucet Timer with Netro Hub (US)
Price: $99.00
Model:
Threads:
In Stock
Shipping Policy
Quantity
Netro Pixie Z1
Paired with the Netro Hub to create easy and smart hose faucet watering
Instant Control
Working with the Netro Hub, your Pixie Z1 will always be online and connected to the internet, allowing you to control and monitor your watering schedules remotely and instantly through the Netro app or web interface.
Extended Range
The Netro Hub acts as a bridge between the Pixie Z1 timer and your home internet. Using advanced wireless technologies, the timer can keep reliable connectivity when placed up to 25 meters away from the hub.
Long Battery Life
The Pixie-Z1 timer can typically operate for up to one year on two AA alkaline batteries, covering all the watering seasons no matter where you are.
Easy Scheduling
Powered by the Netro Cloud, the Pixie Z1 does the thinking for you and calculate the watering time & duration automatically according to weather conditions and your garden settings.
Multiple Timers
Get an additional Pixie Z1 timer for only $69. The Pixie Z1 is the more economical solution if you have two or more hose faucets in your automatic watering system.
Model: Pixie-Z1-H Box Contains: – Smart hose faucet timer, quick installation guide, hub, charging cable, power adapter Technical Specifications of Timer – Dimensions: 6.5 X 4.3 X 1.9 (inches) / 164.5 X 110 X 48 (mm) – Weight: 14.5 oz / 410 g – Local wireless network: 2.4Ghz – Operating temperature: 32℉ to 122℉ / 0℃ to 50℃ – Water pressure: 0.02MPa to 0.8Mpa – Threads: US standard 3/4” GHT (Garden Hose Thread) – Power: two AA alkaline batteries Technical Specifications of Hub – Dimensions: 3.2 X 3.2 X 1.1 (inches) / 81 X 81 X 27 (mm) – Weight: 2.8 oz / 78 g – Input voltage: 5V DC – WiFi: 802.11n, 2.4Ghz – Local wireless network: 2.4Ghz – Maximal number of end devices: 8 – Operating temperature: -4℉ to 122℉ / -20℃ to 50℃ Warranty – 2-year limited hardware warranty
user_manual_pixie_z1h.pdf
Wi-Fi Connection
Cloud Services
Watering Schedules
Weather Data
Watering Regulations
Sensors
Overall rating: 5/5
2023-07-12 07:18:17
Tengo varios productos Netro (Sprite 12 zonas y 2 pixies z1) y aparte de funcionar todos perfectamente, en un momento puntual en que tuve un problema, desde su departamento de soporte técnico me atendieron inmediatamente y con extrema eficacia.
