Accessories
Sprite-6, with 24V power adapter (US)
List Price:
Price:
$89.00
You Save:
$30.00
Model:
Power Adapter:
In Stock
Mechanical Specifications
– Dimensions: 5.7 X 5.7 X 1.2 (inches)
– Weight: 8.2 oz / 230 g
– Output: 6 zones + 1 master valve
– Wire size: 18 AWG to 22 AWG
– Box contains: smart irrigation controller, AC adapter, wall screws, quick installation guide
Electrical Specifications
– AC Input: 24VAC, 50/60Hz, 800mA
Warranty
user_manual_sprite.pdf
Wi-Fi Connection
Sprite will continue to execute the next 32 pre-loaded schedules.
Cloud Services
Watering Schedules
Weather Data
Watering Regulations
Sensors
![47](/assets/47-7e8b9b3e2c9922b7bd0dcb5dd04169e974768e645fde03577458130e0f6d7267.png)
Member since 2017-06-18
Overall rating: 5/5
2024-06-23 18:20:09 UTC
I have been using this since its initial release (the developers were collaborating with me on several issues I reported). I left my original controller at my old house and have been renting for the past three years.
![29](/assets/29-04e898a7390be0cecb0dc3f398177720e5853db151efd40436d1402faddcdb75.png)
xergyo
Member since 2021-08-09
Overall rating: 5/5
2023-07-12 07:17:58 UTC
Tengo varios productos Netro (Sprite 12 zonas y 2 pixies z1) y aparte de funcionar todos perfectamente, en un momento puntual en que tuve un problema, desde su departamento de soporte técnico me atendieron inmediatamente y con extrema eficacia.
![30](/assets/30-fae1cde7a695ea0d78223077b3037a202df5b12ae33a023096ea6e89c2cd79e4.png)
Quim Retbin
Member since 2022-02-03
Overall rating: 5/5
2022-02-13 14:42:15 UTC
Todo muy bien! Me gusta mucho el diseño moderno y lo comodo que sera, tambien disponible para las 6 zonas, desde la app tiene mas opciones de lo esperado me gusta mucho espero que dure.
![36](/assets/36-706128829af9fd23dc49d8482d7fb35e18934119530c95d467386850177f81cd.png)
Ilse Berkeley
Member since 2017-03-22
Overall rating: 5/5
2020-06-19 05:09:34 UTC
Using it for 3 years with only a couple of connection issues. Great product and great app!
![12](/assets/12-10b2538dad2ef7b436bfafb3f14abb9f7c35692515b93959da073783e4655354.png)
Douglas Ely
Member since 2018-09-03
Overall rating: 5/5
2019-07-18 05:07:24 UTC
I tried this unit personally before I began to use it professionally. It worked great. The physical setup was simple. other than a screwdriver to attach it to the wall, there are no other tools needed. The zone valve hookups and power supply are push and release so the whole thing took about 5 minutes. The software configuration is a simple download and then there is a menu driven setup procedure that guides you from there. You can just go with the pre-programmed schedule (pretty good on its own) or customize your own parameters. There are modifications for soil type, type of plant (grass, shrubs, flower garden etc.), direct/indirect sunlight, slope, soil moisture. You can really fine tune each location or application. You can select different programs too. I like the one for new seed. I just set the controller for new seed and it keeps the soil moisture consistent to ensure fast germination. Once the grass starts growing I just set the program back to more regular watering. You really can just install this and then let it take over your watering schedule. Another welcome feature is that I can activate the zones from a remote location. For example: I can walk around the yard and turn on each zone using my phone. No more running from the garage or basement back and forth to each zone to see if it has come on or not or to adjust each head and then run back down to switch to the next zone. I am also using far less water than if I set the schedule myself so that is both financially and biologically responsible!
I have since installed 6 of these Sprites for various family and clients. all are very happy with them. In one instance, the controller did not connect to the wifi so I contacted the manufacturer. They immediately assessed the problem and shipped me a replacement. I have had to contact them for programming/installation questions a couple of times and they are very fast and accurate with their responses. I even called them a couple of times and they were very helpful, but the email responses are so quick that I now prefer to contact them using that method.
I would recommend this control system for upgrading your current irrigation system to a more biologically based approach to watering. The predictive rainfall feature alone is worth the move. It doesn't have to wait for rainfall to shut off the system. It is able to prevent it from coming on at all if there is rain in the forecast. If the rain doesn't happen, it adjusts for than the following day. Smart.
I am very impressed with this product. The programmers have good focus on plant and homeowner requirements and have incorporated them into the interface.
