Ac adaptor
Cisco -
更新時間 2024-08-24 21:45:58 UTC
瀏覽: 3396   回覆: 1
Van Klaveren Patrick
更新時間 2024-08-15 10:04:53 UTC
瀏覽: 3513   回覆: 1
Smart watering very stupid
Ruth Wengert
更新時間 2024-08-13 14:22:33 UTC
瀏覽: 3559   回覆: 1
Terminal 1 not working
Morgans_Home
更新時間 2024-08-12 01:27:03 UTC
瀏覽: 3504   回覆: 1
Sensor plat
Tiago Lourenco
更新時間 2024-07-28 12:17:00 UTC
Good afternoon
I have plant sensors in all zones, and they block.
Sometimes i have my grass really dry and the sensor have 70/80 % of humidity.
I turn them off change place like 2 cm, turn them in again and they have the correct humidity.
Anyone experience this?
Thank you in advance
瀏覽: 3856   回覆: 3
Metro timer
Anne McNamara
更新時間 2024-07-04 13:16:31 UTC
Everything shows it should be running, but it doesn’t wake up. I have it set for online during watering periods. It says it’s communicating but it’s not running. How do I wake up metro when I want to communicate
瀏覽: 3674   回覆: 1
Red dot
更新時間 2024-07-03 18:53:21 UTC
What is the significance of a red dot next to the green bell ?
Do not see anything anywhere and have not received any notice.
瀏覽: 3642   回覆: 1
Start two Zones at the same time
Timmmee
更新時間 2024-06-22 18:15:57 UTC
Dear netro team,
I missing the function that I can open two zones at the same time.  If this is possible you could combine different valves.
This would be a huge advantage.
Thanks for your response.
瀏覽: 3551   回覆: 1
Netro Sprite offline
David Domingues
更新時間 2024-06-20 06:58:04 UTC
Since 2 days now, my netro Sprite is offline.
The light is solid  but quickly blinks each 6 seconds.
What should I do?
Are Netro servers online?
David.
瀏覽: 3657   回覆: 1
Weatherflow Tempest PWS Weather Provider
cseward
更新時間 2024-06-17 19:59:17 UTC
I noticed that Weather Flow PWS was added as a weather provider for Netro and successfully linked my Weather Flow Tempest with my Netro Pixie Z1+Hub+Whisperers.  However I have a few questions:
1) There seems to be no way to remove or change the link to Weatherflow, like selecting another station.  Can you add a way to do that?
2) Since linking to Netro, I have changed the name of my Tempest Device on their platform from the default serial number to a descriptive name, but Netro still shows the old name for the device when I click on it in the Weather Provider menu, is that a problem, or are they still linked?  (and if it is a problem, how can I update the link?)
3) What data is actually pulled from Weatherflow?  The forecast shown in the Netro app does not line up exactly with what my tempest shows, nor do the rainfall totals on the discover tab.
4) I have also linked my Tempest with Weather Underground and can use them as a Weather Provider instead.  The Netro app says Weatheflow PWS shares 9 days of forecast and 1 day of history, while Wunderground PWS shares 7 days of forecast and 7 days of history.  I prefer not relying on an additional middleman to link my tempest to Netro, but is it better to have the additional history or additional forecast?
瀏覽: 3591   回覆: 1
Changing order of zones
Sasha Obradovic
更新時間 2024-06-15 02:06:31 UTC
Hello, can you please tell me is there possibility to switch order of zones how they appear in the menu
瀏覽: 3541   回覆: 1
Orario programma intelligente
Mattia Forti
更新時間 2024-06-14 16:13:19 UTC
Salve, imposto in PREFERENZE due cornici di irrigazione.
Dalle 3 alle 9
Dalle 23 alle 24
Il programma intelligente continua ad irrigare alle 18.
Salvata più e più volte questa impostazione di orario ma continua ad irrigare spesso alle 18.
Come risolvere?
瀏覽: 3569   回覆: 1
My New Whisperer 2 doesn't switch on
JDo REY
更新時間 2024-06-12 16:24:26 UTC
My New Whisperer 2, after worthing fine for 2 days connected in the garden, now doesn't switch on any more, even after USB charging (showing full charge green light near the USB socket). It's offline and nothing happens when pushing the power button once, for 3, 5, 10, 25, 30 seconds.
What do you think ?
瀏覽: 3593   回覆: 1
My zone is leaking water even when it’s not running.
kgonzales
更新時間 2024-06-12 03:11:04 UTC
What should I do? Water is leaking out of my zone 5 only when they aren’t being used creating giant puddles in my yard. Any help?
瀏覽: 3536   回覆: 2
Pixie Hose Faucet Timer
Robert Greenwood
更新時間 2024-06-06 22:42:03 UTC
When I put a fully charged battery in the timer, the white light comes on. I press the button to try to link with the WIFI router, nothing happens. I never see a white flashing light. If I press the button again a steady red light comes on. I have another Pixie and it links quickly with the router and works well so I know the WIFI router is working well but it never sees the water timer that is not working.
瀏覽: 3604   回覆: 1
Water timer pixie
Anne McNamara
更新時間 2024-06-06 19:53:04 UTC
How do I lengthen the duration from 60 minutes to longer
瀏覽: 3615   回覆: 1
Problem with flow interruption
Giuseppe Natilli
更新時間 2024-06-04 16:13:25 UTC
irrigation programs don't stop. even if the timer stops, the water continues to flow out. even if active in manual mode, I can't stop the water flow.
瀏覽: 3675   回覆: 1
Mutiple Zone runing at the same time and half the zone (6-12) not actually running
harrywhl
更新時間 2024-06-01 23:57:27 UTC
My Netro-12 is currently running 5 zones at the same time when it was mannually turned on to go each zone at a time, also, the back end of the zones (6-12) does not respond to the app commands and whenever the app said the zones were turned on, it was still the first five zones that were running.
瀏覽: 3565   回覆: 1
Cant connect
B Ray
更新時間 2024-06-01 22:41:52 UTC
How close does this pixie z1 faucet timer have to be to the hub because it’s approximately 21 ft from it…
WiFi connected
Hub light is solid green
And the timer is offline
Won’t stay connected
瀏覽: 3591   回覆: 1
Two times zone watering
Jerry Agresti
更新時間 2024-05-30 17:03:18 UTC
Hi there. How can I program specific zones to water twice in one day?
瀏覽: 3575   回覆: 1
