Reset Moisture Level
firewally
Updated at 2019-07-06 14:06:03 UTC
View: 5080   Answer: 1
Home Assistant
David
Updated at 2019-07-06 09:33:48 UTC
View: 5164   Answer: 1
Saurik
Updated at 2019-07-04 07:12:42 UTC
View: 5202   Answer: 1
Smart watering
John Jessee
Updated at 2019-07-03 22:25:57 UTC
View: 4748   Answer: 1
Forecast provider for Italy
Gabriele Gianello
Updated at 2019-07-03 11:53:03 UTC
View: 5367   Answer: 1
Translation Issue - ITALIAN
Gabriele Gianello
Updated at 2019-07-03 05:18:10 UTC
Hi! I’m excited about Netro App and I’d love to contribute opening a support ticket for a double check of translations.
There’s a lot of minors but one is always in evidence: the names of the DAYS OF THE WEEK (please see the attached image) .
The right translation is:
SUNDAY : DOMENICA
MONDAY: LUNEDÌ
TUESDAY: MARTEDÌ
WEDNESDAY: MERCOLEDÌ
THURSDAY: GIOVEDÌ
FRIDAY: VENERDÌ
SATURDAY: SABATO
THE FIRST day of the week in Italy is always settend Monday
View: 6971   Comment: 1
Rain versus no rain
Dennis G
Updated at 2019-07-03 03:27:38 UTC
View: 5325   Answer: 1
Notifiche push
Andrea Casali
Updated at 2019-07-01 19:07:47 UTC
Ciao, è possibile ricevere delle notifiche push tutte le volte che parte l’irrigazione?
View: 4940   Answer: 1
Updated at 2019-07-01 16:32:17 UTC
View: 5471   Answer: 1
Adapter in EU
Lukas2002
Updated at 2019-07-01 11:06:15 UTC
I am Lukas from the Netherlands. I have ordered a Netro sprite-6 on without a power adapter.
In the Netherlands we have 230V AC on the power grid. I am having serious trouble to find a power adapter that goes to 24V AC 800mA.
The only one I can find has an output of  24V AC 1000mA, will that be ok?
Or is there a better alternative out there?
Lukas Zwanenburg (NL)
View: 5516   Answer: 2
Nipun Devlekar
Updated at 2019-07-01 01:01:18 UTC
View: 4712   Answer: 1
internet may not be available
Bruce Vermeulen
Updated at 2019-06-30 18:31:02 UTC
Bruce
View: 4976   Answer: 0
Whisper shipping
Matty B
Updated at 2019-06-30 13:31:58 UTC
I ordered a sensor and have yet to receive it. It has been well past 4 weeks.
Number is: 180404 ― May 17, 2019
What is the status of the order?
View: 5531   Answer: 2
WiFi connection
Andrew
Updated at 2019-06-27 00:49:26 UTC
View: 4811   Answer: 0
Watering Times
terry
Updated at 2019-06-26 22:02:52 UTC
View: 4977   Answer: 1
PIR sensor
Vito Favaretto
Updated at 2019-06-26 20:06:49 UTC
I always find cats dejections on my garden but I  cats are not mines. I had an idea to avoid these cats' gift, installing a PIR sensor connected to netro controller by wifi that transmit a signal to water garden at cats presence. Cats don't love water so they leave my garden very quickly.
Do you think you can build a sensor like this?
I.could be a beta tester ;)
View: 5326   Answer: 1
Google Home app questions- just installed my Netro Sprite!
jdonhowe
Updated at 2019-06-26 04:16:22 UTC
I just installed my Netro Sprite and am having fun investigating all the options. After some false steps, I was able to link it to my google home account. so, my questions:
1. When I go through google, do I always have to say "Okay, Google, talk to Netro Sprite", and then when Netro responds, give a command, such as "water zone 1 for five minutes". Is there any way such that I can say directly to google "water zone 1", and Netro will do it (like smart light switches)- I don't have to tell google to tell TP-link to turn on the bedroom light!
2. I know that Netro controls zones sequentially (only one on at a time). When I ask Netro (through google home) to water zone 1 for x minutes, it then asks "what else can I do for you". If I say "water zone 2 for x minutes, it looks like it immediately turns off zone 1, and turns on zone 2. So, does "what else" mean "instead of", rather than "in addition to" the first command? Is there any way to get it to recognize sequential zone commands?
3. I've renamed my zones in the Netro app (nice touch- always hated having to remember zone numbers with old controller. Is there any way for the Netro google link to recognize (like google home does with devices) the name of a zone? It would be great to say "water front lawn for five minutes" instead of having to remember which zone it is.
View: 5328   Answer: 1
Support for IFTT
Shahid Warraich
Updated at 2019-06-25 17:25:17 UTC
View: 4872   Answer: 1
Remove whisperer
Dan Orms
Updated at 2019-06-25 16:17:24 UTC
View: 5361   Answer: 1
Restriction for specific days
Updated at 2019-06-24 18:20:32 UTC
I want to create restrictions for a set of specific days in the future.  Birthdays of family members for example. Or days that I have outdoor entertainment planned. I want to set these up long in advance (before a smart schedule has been scheduled.) How can I do this?
View: 5312   Answer: 1
