Subsoil moisture level
Swaroop Jay
Updated at 2019-05-28 17:13:12 UTC
View: 5879   Answer: 2
Jon Storch
Updated at 2019-05-27 19:41:14 UTC
Why did it run this morning?
Jon Storch
View: 6951   Answer: 1
Don’t Stop !!
Eduardo Ariste
Updated at 2019-05-26 11:27:42 UTC
View: 6512   Answer: 1
Netro off line
Updated at 2019-05-25 02:59:21 UTC
View: 7152   Answer: 1
Joshua Berk
Updated at 2019-05-23 18:39:21 UTC
View: 7055   Answer: 1
Can't see answers to questions
Stan Bumgarner
Updated at 2019-05-23 00:30:01 UTC
I can see the question and can see that someone has answered it. How do I see the answer?
Stan
View: 6608   Answer: 1
Remote Access?
Oliver Pettit
Updated at 2019-05-22 01:53:35 UTC
Oliver
View: 7061   Answer: 1
Manually skip next watering
Randy Ziffer
Updated at 2019-05-19 16:47:13 UTC
View: 6814   Answer: 2
jpmeyer81
Updated at 2019-05-19 15:04:11 UTC
View: 6932   Answer: 1
Roianne Cox
Updated at 2019-05-19 13:52:50 UTC
View: 6505   Answer: 1
Dennis N
Updated at 2019-05-18 17:52:30 UTC
View: 6561   Answer: 1
David Claridge
Updated at 2019-05-18 13:21:53 UTC
View: 6602   Answer: 1
Steven V
Updated at 2019-05-18 13:08:55 UTC
View: 6615   Answer: 1
Hot weather algorithm
Joshua Berk
Updated at 2019-05-17 16:15:51 UTC
View: 7201   Answer: 2
Whisperer stopped working
Pelle Fisk
Updated at 2019-05-17 13:30:13 UTC
View: 7730   Answer: 2
Manual mode fail to shut off
Updated at 2019-05-16 02:05:13 UTC
View: 7111   Answer: 1
Updated at 2019-05-14 07:01:36 UTC
View: 7676   Answer: 2
Problemi con Google home
Max Point
Updated at 2019-05-12 08:36:40 UTC
Massimo
View: 6773   Answer: 1
is the Pixie faucet joint (both in and out) GHT (Garden Hose Thread) or NPT (National Pipe Thread)
Oliver Pettit
Updated at 2019-05-09 01:33:23 UTC
Could you please confirm if the Pixie faucet joint is GHT (garden hose thread) or is it NPT (National Pipe Thread)?
I'm looking for adapters in Australia to use this unit and its unclear what the size/type the faucet is.
View: 7220   Answer: 1
Henry
Updated at 2019-05-06 19:40:59 UTC
same issue...
so what to do with it?
View: 6956   Answer: 2
