How to Water Trees and Shrubs
Updated at 2018-06-04 10:07:08 UTC
1.How to Water Shrubs
2.How to Water Trees
Don't wait for the plants to tell you with wilting and leaves dropping off. Then youll just be watering to keep the plants roots alive so it may possible come back later. Inspect the soil. Dig around with your hands, soil probe, garden trowel, or shovel. Youll be able to tell quickly how far down you are actually watering.
Resources
View: 10398   Comment: 3
Updated at 2018-06-04 10:03:46 UTC
References
View: 9972   Comment: 0
