itsthesun
Updated at 2019-08-06 20:42:23 UTC
View: 4895   Answer: 1
Sprite doesn't open valve
Tony D.
Updated at 2019-08-06 20:38:31 UTC
View: 5539   Answer: 1
Updated at 2019-08-06 11:03:17 UTC
View: 4884   Answer: 1
changing watering zone times?
Updated at 2019-08-06 01:53:14 UTC
View: 4816   Answer: 1
Install
Daniel Alman
Updated at 2019-08-05 15:17:08 UTC
View: 4731   Answer: 1
sprite losing connection
Robert hays
Updated at 2019-08-04 15:42:10 UTC
View: 4759   Answer: 1
Can my whisper control 2 zones?
L F
Updated at 2019-08-04 02:09:24 UTC
I have two zones for the grass in my backyard and want to connect 1 whisper for both zones since its one small piece of grass.  How can I do this?
View: 5079   Answer: 1
Promise Made- Promise KEPT!
Updated at 2019-08-03 04:32:30 UTC
View: 4925   Answer: 0
Where's our promised update?
Updated at 2019-07-31 11:19:38 UTC
View: 5026   Answer: 1
water amount
Gérard GALBOIS
Updated at 2019-07-31 05:37:55 UTC
View: 4606   Answer: 1
Low pressure in zones
Hussein Diab
Updated at 2019-07-29 16:36:31 UTC
View: 4993   Answer: 1
OnePlus Venom
Updated at 2019-07-29 03:48:51 UTC
What does that mean???
View: 4829   Answer: 1
Updated at 2019-07-29 03:11:08 UTC
Add or delete users
 Access rights of shared users
Manager’s access rights:
Player’s access rights:
View: 9976   Comment: 4
Hunter sprinklers
Richard Mundy
Updated at 2019-07-28 20:37:35 UTC
View: 5018   Answer: 2
riteshmantravadi@gmail.com
Updated at 2019-07-28 15:22:01 UTC
Can you pleas ehelp?
View: 6763   Answer: 2
going backward from topic item
gilles z
Updated at 2019-07-28 05:40:18 UTC
When i read an answer on this forum (from the app)
how can i return back to the previous list  of topics (without doing home button)?
View: 4539   Answer: 1
wrong translation in French
gilles z
Updated at 2019-07-28 05:37:17 UTC
name is translate with ‘prénom’ (meaning= first name) correct translation is ‘nom’
maybe you can have help from users to have a perfect translation in all languages
View: 4547   Answer: 1
30 minutes = 10 minutes X 3
Paul Como
Updated at 2019-07-27 11:49:20 UTC
How do I set my program to run each zone for 30 minutes each, but water 10 minutes 3 times each.  I thought this used to be an option, but I don’t see it.
View: 4536   Answer: 1
Wrong translation - Italian app
Sergio Bertolino
Updated at 2019-07-27 06:48:11 UTC
Part 2 of my observation of the app content:
Months translation:
The month of May is Maggio
You translated in Potrebbe which is the translation of the verb Can.
Best regards.
Sergio
View: 4604   Answer: 1
Sergio Bertolino
Updated at 2019-07-27 06:44:54 UTC
Good morning.
I like the app, also in Italian is well done and intuitive to understand and to program. It’s full of interesting info and give plenty of advice. You need to modify few words that have probably been translated thru a web based translator. The days of the week are:
Monday = Lunedí
Tuesday = Martedí
Wednesday = Mercoledí
Thursday = Giovedí
Friday = Venerdí
Saturday = Sabato
Sinday = Domenica
View: 4431   Answer: 0
