Tim Foster
Updated at 2019-12-05 17:56:44 UTC
View: 5153   Answer: 1
Can't add new managers
Tim Foster
Updated at 2019-12-03 20:00:25 UTC
View: 4756   Answer: 1
Product request: leak detector
Joshua Berk
Updated at 2019-12-03 05:45:42 UTC
I would love to see a leak detector we could install onto the water lines that could communicate the amount of water used and detect leaks. Like the one Rachio offers.
View: 5025   Answer: 1
Wire Gauge
Brian Paternostro Paternostro
Updated at 2019-12-02 15:14:19 UTC
Replacing old Toro system,  all my wires from the zones are too thick to place into the system.  Do you have a wire gauge I can slim down the wires to make it work?
View: 5241   Answer: 1
Whisperer settings
Manuel Roca
Updated at 2019-11-30 23:47:29 UTC
I’m wondering how many whisperer units I need to have if I my garden has 8 zones. Do I have to get 1 per zone?
View: 5225   Answer: 1
Works in Uruguay?
Sebastian Diaz
Updated at 2019-11-26 20:39:14 UTC
Hello I bougth my first netro sprite but i can not find the country Uruguay and i the smart not work correctly, how i can resolve this issue?
View: 5043   Answer: 1
Smart zone enabled
Steve Kalani
Updated at 2019-11-25 18:36:19 UTC
View: 4545   Answer: 1
Manuel Roca
Updated at 2019-11-22 17:20:29 UTC
This is an easy question
View: 4873   Answer: 2
Black Friday
John Mayer
Updated at 2019-11-22 10:40:22 UTC
Hello Netro, will you have a black Friday offer?
View: 8346   Answer: 1
Daylight savings
Craig Neidle
Updated at 2019-11-13 18:34:27 UTC
Haow can i change this?
View: 5011   Answer: 1
How to replace an old controller with more than 12 zones
Updated at 2019-11-06 09:20:19 UTC
If your old controller has more than 12 zones, you will need to have 2 Netro controllers to replace it. Please follow the diagram below to safely wire the 2 controllers:
Now you can use the 2 C slots for the common wires and the 2 sets of 1-12 slots for the zone wires. If you do not have a master valve or pump, just ignore the orange wires.
IMPORTANT: the blue wire has to be connected to the left 24VAC on both controllers and the yellow wire has to be connected to the right 24VAC on both controllers.
Please contact us if you need the wire connectors shown in the picture.
View: 6701   Comment: 0
Riego netro para tepes
Manuel C
Updated at 2019-10-23 09:36:27 UTC
Hola,
View: 6810   Answer: 1
What about blowout?
Burghardi
Updated at 2019-10-18 02:06:15 UTC
Why doesn’t this one?
View: 4859   Answer: 2
Sangjin Lee
Updated at 2019-10-17 03:41:11 UTC
View: 4967   Answer: 1
Brian Hobbs
Updated at 2019-10-15 01:58:49 UTC
View: 4971   Answer: 1
Weird watering plan
Manuel Roca
Updated at 2019-10-12 11:34:00 UTC
View: 4683   Answer: 1
Installation Direct to pump
Tim Foster
Updated at 2019-10-03 11:23:32 UTC
I have the following:
View: 5494   Answer: 2
sqwu
Updated at 2019-09-30 13:51:09 UTC
View: 4890   Answer: 1
Nguyễn Vinh
Updated at 2019-09-30 06:46:55 UTC
View: 5226   Answer: 2
hanz.blatt@gmail.com
Updated at 2019-09-29 13:59:02 UTC
View: 8465   Answer: 2
