Actualizado 2020-06-22 07:37:55 UTC
Ver: 7679   Comentario: 5
Installed perfectly
Lakeside Gardens
Actualizado 2020-07-12 14:57:53 UTC
And we are off and running.   Whisper went in the ground and started reporting right away.  Would be nice to connect it to my Ambient weather station as well.
Ver: 6266   Comentario: 1
Addiel Isaac Moldes
Actualizado 2020-07-19 11:43:54 UTC
Ver: 6004   Comentario: 2
Maximum wire distance between controller and valves
Actualizado 2021-01-16 14:20:49 UTC
Below is a chart indicating the maximum wire runs that can be used when installing AC solenoids and valves.
22 AWG: 600 feet
20 AWG: 700 feet
18 AWG : 850 feet
16 AWG: 1300 feet
14 AWG: 2000 feet
Ver: 5839   Comentario: 0
