Actualizado 2018-09-12 07:54:55 UTC
Resources:
Ver: 439642   Comentario: 95
Thresholds
Shady Trails
Actualizado 2023-12-23 16:16:15 UTC
Ver: 4752   Comentario: 3
Junk box pixie
Ray Williams
Actualizado 2021-06-17 22:30:16 UTC
So Dissatisfied
Ver: 6536   Comentario: 1
Actualizado 2023-11-07 13:27:20 UTC
Ver: 37200   Comentario: 1
Good results
R C
Actualizado 2023-10-24 18:55:29 UTC
Ver: 5944   Comentario: 2
Vincent Coutinho
Actualizado 2023-02-18 16:26:02 UTC
Ver: 5413   Comentario: 2
Netro Plugin for Jeedom
Actualizado 2022-11-30 22:07:13 UTC
Hello guys,
kcofoni
Ver: 5710   Comentario: 1
Kickstart the Netro Zigbee Hub and Pixie-Z1
Actualizado 2022-09-13 06:23:11 UTC
To the Netro community:
We are excited to introduce our new products, the Netro Zigbee Hub and the new smart timer Pixie-Z1. They combined deliver a different experience of smart watering system.
The Netro Zigbee Hub hosts a long-range local Zigbee network that links all the end devices. It connects to your router (wireless or wired) to transfer data between the end devices and the Netro cloud service. The Hub will work with all our Zigbee products including the new timer Pixie-Z1(introduced below) and the new soil moisture sensor coming this year, as well as the new 4-Zone sprinkler controller and the new weather sensor coming next year.
The new host timer Pixie-Z1 is re-designed from the original Pixie timer in many ways:
1. Always online for instant quick runs. No more sleep mode
2. Powered by two AA alkaline batteries with approximately one year of battery life. Notifications on low battery
3. Supports Google Home and Google Assistant
The Netro Zigbee Hub and Pixie-Z1 are expected to ship in September. To join the Tester program please email to info@netrohome.com and we will send you a discount code in return for feedbacks.
Ver: 125135   Comentario: 3
Android devices logout issue
Wency Pan
Actualizado 2022-07-12 06:35:45 UTC
Ver: 6183   Comentario: 1
Rain presiction is wrong
Paul X
Actualizado 2022-07-04 15:12:41 UTC
Ver: 5929   Comentario: 1
Manual operation
Paola Pinnavaia
Actualizado 2022-06-17 23:21:30 UTC
It is a serious problem
Ver: 75622   Comentario: 2
Ron
Ron Ferrars
Actualizado 2022-05-30 14:12:27 UTC
Ver: 6189   Comentario: 1
Sleeping mode
Fabrice GOUFFRAN
Actualizado 2022-05-18 10:11:40 UTC
Like the app update.
Dave Henderson
Actualizado 2022-04-09 02:14:47 UTC
Ver: 66054   Comentario: 3
Lloyd Walter
Actualizado 2022-03-23 08:31:18 UTC
Ver: 6750   Comentario: 3
Mi experiencia con Netro
Marcelo Vasquez
Actualizado 2021-11-25 18:21:23 UTC
Hola les cuento mi experiencia con Netro, trabajo actualmente en el estado de Nueva York, y tengo 500 plantas de bluebery en Chile souh America, y lo controlo desde acá, he tenido excelentes resultados con el sensor de humedad, me hubiese gustado que el sensor fuera más largo, pero con el actual se ha manejado perfecto, también creo que deberían diseñar una caja más robusta para exteriores, estoy muy feliz con la aplicación con el equipo y el sensor.
Ver: 6563   Comentario: 2
Nuova interfaccia penosa!!
Andrea DiPi
Actualizado 2021-11-05 03:00:01 UTC
Ver: 7202   Comentario: 1
Actualizado 2021-10-07 05:53:59 UTC
Dear Netro users,
Ver: 6606   Comentario: 0
Netro and Home Assistant
Jens Wymeersch
Actualizado 2021-07-28 18:18:16 UTC
Ver: 9339   Comentario: 7
Whisperer availability
Actualizado 2025-03-16 18:50:01 UTC
Ver: 2531   Comentario: 1
