Can’t open netro app
Marcos Sanz
Actualizado 2023-06-12 16:35:22 UTC
Ver: 4110   Comentario: 1
A single rain day
Rob Nelson
Actualizado 2023-07-15 11:22:50 UTC
Ver: 4396   Comentario: 1
Brian Brun
Actualizado 2023-08-02 01:14:30 UTC
Ver: 4418   Comentario: 1
Please issue a good manual.
Mark Menzhausen
Actualizado 2023-08-27 15:04:55 UTC
Ver: 5004   Comentario: 1
Irrigreen sprinklers
Actualizado 2023-09-09 08:34:33 UTC
Combining with the whisperers
https://irrigreen.com/
Ver: 4608   Comentario: 0
Alexa Skill
Louise Brinkman
Actualizado 2023-10-13 01:00:17 UTC
Ver: 4795   Comentario: 3
Actualizado 2023-11-07 06:10:16 UTC
Ver: 5145   Comentario: 0
Good results
R C
Actualizado 2023-10-24 18:55:29 UTC
Ver: 5941   Comentario: 2
Actualizado 2023-11-07 13:27:20 UTC
Ver: 37196   Comentario: 1
Thresholds
Shady Trails
Actualizado 2023-12-23 16:16:15 UTC
Ver: 4751   Comentario: 3
Richard
Actualizado 2024-01-07 22:48:08 UTC
UPDATE 8/1/2024
UPDATE: 5/1/2024
UPDATE: 4/1/2024
ORIGINAL:
Ver: 5141   Comentario: 11
Actualizado 2024-09-19 03:30:21 UTC
Ver: 20667   Comentario: 3
Actualizado 2018-06-04 12:37:29 UTC
1.Year One
3.After the first week or so
4.Years Two to Three
5.After Year Three
Helpful Tips
Before you water:
Ver: 10500   Comentario: 4
Fixing App "Contact Us" feature not working for Andorid
Actualizado 2019-07-15 01:37:42 UTC
To the Netro android users,
Our Netro app crashes for android on sending messages though Settings->Support->Contact Us suddently. Our R&D are fixing this issue and we expect to have the fixes in place in a few days. We are sorry about the inconvenience.
If you have any questions, please write to us support@netrohome.com and we will make sure to deliver technical support in short time.
Thanks again for your support and trust.
Ver: 6971   Comentario: 0
Actualizado 2022-04-24 01:45:07 UTC
Ver: 9374   Comentario: 1
How to Water Trees and Shrubs
Actualizado 2018-06-04 10:07:08 UTC
1.How to Water Shrubs
2.How to Water Trees
Don't wait for the plants to tell you with wilting and leaves dropping off. Then youll just be watering to keep the plants roots alive so it may possible come back later. Inspect the soil. Dig around with your hands, soil probe, garden trowel, or shovel. Youll be able to tell quickly how far down you are actually watering.
Resources
Ver: 10450   Comentario: 3
Actualizado 2018-06-04 10:03:46 UTC
References
Ver: 10032   Comentario: 0
Actualizado 2023-11-07 06:09:05 UTC
Then you should put Sprite in "paused" mode just in case some one (for example the kids) accidentally starts a manually run from the app. To put Sprite in "paused" mode, you can go to the Home page->"Enabled".
Ver: 9364   Comentario: 1
Customization->set rain/temperature/wind threshold to skip watering
Actualizado 2018-10-13 06:19:08 UTC
Netro automatically creates dynamic watering schedules according to local weather, so if you turn on the smart zone feature for your zone, season adjustment will be made with smart watering schedules according to weather.
There are different types of weather restrictions: rain, temperature and wind.
By default, If you turn on the smart zone feature, Netro will skip the schedules (including manual schedules from user programs) when there is a chance of significant rain(>0.2inch).
The default threshold to skip watering when temperature is too low is 0 Celsius degree (32 Fahrenheit) for all the Netro controllers.
You can now customize rain, temperature and wind threshold through Settings->Preferences.
Ver: 7763   Comentario: 0
Actualizado 2023-06-09 06:07:25 UTC
2.Smart watering: Level basic
3.Smart-zone feature disabled
Ver: 16170   Comentario: 12
