Can’t open netro app
Marcos Sanz
Actualizado 2023-06-12 16:35:22 UTC
Ver: 4110   Comentario: 1
Netro sprite
mekanicul Meku
Actualizado 2023-06-11 09:43:07 UTC
Ver: 3695   Respuesta: 1
Srdjan
Actualizado 2023-06-11 05:21:33 UTC
Ver: 4023   Respuesta: 2
Börke Titscher
Actualizado 2023-06-04 08:32:03 UTC
Folks
Ver: 3875   Respuesta: 2
D Hitch
Actualizado 2023-06-03 14:10:58 UTC
Thanks for any help.
Ver: 3831   Respuesta: 1
Nero Sprite
Glenn Thurston
Actualizado 2023-06-02 12:12:10 UTC
Ver: 3725   Respuesta: 1
Smart mode initial watering
Matt Ward
Actualizado 2023-06-02 01:19:52 UTC
Ver: 4038   Respuesta: 1
kaitech
Actualizado 2023-06-01 19:44:40 UTC
How can I troubleshoot it?
Ver: 3729   Respuesta: 1
WU PWS request pixie-Z1
Richard B
Actualizado 2023-05-29 01:04:07 UTC
Ver: 3727   Respuesta: 1
Manuel Run delay
BOBBY BROWNE
Actualizado 2023-05-26 00:37:50 UTC
Why is it when I hit manual run? There’s always a delay.
Ver: 3793   Respuesta: 1
A Netro Spark with no WIFI
Lino
Actualizado 2023-05-25 16:07:02 UTC
Just bought a Spark and realized my home wifi sig doesn’t reach the location where it is installed.
While I sort out how to increase the signal I wonder if there is a way to program the Spark to operate without Wifi
Netro Spark firmware version
Luis T
Actualizado 2023-05-24 15:54:35 UTC
I have a Netro Spark with firmware version 3.2.1. Firmware updates are done without user intervention or how can I perform a firmware update?
Ver: 4098   Respuesta: 1
Frequently disconnection from the wifi
PaoloMassignan
Actualizado 2023-05-24 05:07:48 UTC
My device is always offline unable to connect to the wifi. I have to reset it and then the connection works for a while.
There is a repeater  2 meters from it. The signal is strong.
Ver: 3737   Respuesta: 1
App Showing Ofline
Katie Wallace
Actualizado 2023-05-21 11:09:21 UTC
Ver: 3550   Respuesta: 1
Nitro speak to system
Charlie Patel
Actualizado 2023-05-11 18:55:33 UTC
Ver: 3629   Respuesta: 1
Anupam Kumar
Actualizado 2023-05-11 00:29:18 UTC
Ver: 3593   Respuesta: 1
Home assistant integration
Actualizado 2023-05-03 16:22:33 UTC
I just developed a Netro Smart Garden integration for Home Assistant.
Take a look here if interested: https://github.com/kcofoni/ha-netro-watering.
Ver: 5490   Comentario: 3
Michael Cayless
Actualizado 2023-05-03 15:45:48 UTC
Ver: 3890   Respuesta: 1
Pixie Z1
Jason Willis
Actualizado 2023-05-02 14:13:57 UTC
Jason Willis
Jason@wishsystems.biz
Ver: 3899   Respuesta: 1
Multiple users
Norm Markworth
Actualizado 2023-04-17 00:22:59 UTC
Norm
Ver: 4502   Respuesta: 2
