Spark not working
Mick Faulks
Actualizado 2023-11-26 07:04:12 UTC
Ver: 4113   Respuesta: 1
Scott Flanigan
Actualizado 2023-11-10 17:04:48 UTC
Ver: 4294   Respuesta: 2
Actualizado 2023-11-07 13:27:20 UTC
Ver: 37196   Comentario: 1
Why did the schedule run went it’s raining
Scott Flanigan
Actualizado 2023-10-26 19:00:19 UTC
Why did my system run while we are having constant rain and flood alerts
Ver: 4195   Respuesta: 1
The app is full of useless things
MB
Actualizado 2023-10-19 17:08:43 UTC
MAKE IT SIMPLE AND FAST!
- not possible to run multiple valve at the same time
- app and webapp full of useless things such as the BIG clock in the schedule attached
- interface full of too many things. I dont care about smart watering. why my screen should be full of that?
- setting full of useless things.
- apps should be fast and simple, if you focus on professionals. If you focus on housewives is another story.
- example of ewelink
- not possible to run all the time you want. max 60 minutes. Edit program full of things again.
- under zone there should be the possibility to add the schedule. why you are making an extra menu?? Zone 1 --> prog1 -->start h8.00; finish h.10:00
Ver: 4284   Respuesta: 1
Terrible product?
Andrew Martin
Actualizado 2023-10-16 14:26:31 UTC
Three hours to setup
Ver: 4364   Respuesta: 2
Alexa Skill
Louise Brinkman
Actualizado 2023-10-13 01:00:17 UTC
Ver: 4795   Comentario: 3
Linking Google Home to Netro
cadry1969
Actualizado 2023-10-07 03:21:23 UTC
Ver: 4046   Respuesta: 2
Schedule
Jim Lacy
Actualizado 2023-09-28 02:00:48 UTC
Ver: 4105   Respuesta: 1
My device is offline
carlos davalos melgar
Actualizado 2023-09-17 18:50:32 UTC
How can I reconnect to Wi-Fi
the controller light is green
Please i need help
Ver: 4229   Respuesta: 1
Change Wifi problem
Luciani Daniele
Actualizado 2023-09-12 15:54:28 UTC
Ver: 3909   Respuesta: 1
Scheduling Issue
Steve Loesch
Actualizado 2023-09-12 13:59:31 UTC
First.
Second.
Ver: 4046   Respuesta: 1
Whisperer stake cracked
Actualizado 2023-09-09 20:22:46 UTC
Ver: 4152   Respuesta: 1
Arghhh, so horrible
Jake Tanner
Actualizado 2023-09-09 16:24:29 UTC
Ver: 4040   Respuesta: 1
smart watering
Diane Fetherolf
Actualizado 2023-09-04 22:29:30 UTC
Ver: 3714   Respuesta: 1
Sensor offline
Tonycimo
Actualizado 2023-08-28 21:29:20 UTC
How csn i solve it?
Czn i check snything?
Ver: 3823   Respuesta: 1
Not connecting
Ali M
Actualizado 2023-08-27 05:07:14 UTC
Ver: 3799   Respuesta: 1
Xavi
Actualizado 2023-08-25 21:23:22 UTC
Ver: 3744   Respuesta: 0
Jacob Matheny
Actualizado 2023-08-22 15:15:10 UTC
Ver: 3950   Respuesta: 1
Jacob Matheny
Actualizado 2023-08-22 15:14:09 UTC
Ver: 3972   Respuesta: 0
