Why no cycle soak setting?
Actualizado 2023-07-08 19:56:33 UTC
Ver: 4145   Respuesta: 1
Pixie Z1
ke7vng
Actualizado 2023-07-08 02:25:00 UTC
Ver: 3779   Respuesta: 1
Not enough watering
Manuel Herbst
Actualizado 2023-07-03 20:19:28 UTC
Hey everybody,
Can anybody help me?
Manuel
Ver: 4192   Respuesta: 1
Cambio días de demora.
Lino
Actualizado 2023-07-03 06:35:04 UTC
Ver: 3855   Respuesta: 2
Actualizado 2023-06-27 08:48:51 UTC
Ver: 4131   Respuesta: 1
Actualizado 2023-06-26 12:06:15 UTC
  1.  it's raining or
Ver: 4121   Respuesta: 1
Zones not watering
joefil
Actualizado 2023-06-22 16:54:38 UTC
Your help is appreciated
Ver: 3928   Respuesta: 1
Start-end time not working
Fabio Silvestri
Actualizado 2023-06-21 05:20:31 UTC
Ver: 4171   Respuesta: 3
Actualizado 2023-06-19 09:25:40 UTC
Ver: 4271   Respuesta: 2
Actualizado 2023-06-10 17:50:24 UTC
Ver: 4062   Respuesta: 1
Actualizado 2023-06-09 06:07:25 UTC
2.Smart watering: Level basic
3.Smart-zone feature disabled
Ver: 16170   Comentario: 12
Custom sprinkler flow rate
Jure
Actualizado 2023-06-01 14:42:27 UTC
Ver: 4135   Respuesta: 1
New grass from seed
D Berggren
Actualizado 2023-05-31 01:11:58 UTC
Ver: 3803   Respuesta: 1
Rotor head
Sjors Janssen
Actualizado 2023-05-25 19:15:07 UTC
I've just been using a Netro Spark to water my garden. I have set up 3 zones. Two of these zones have a rotor head sprinkler. However, they don't cover the same area. One of them rotates over 90 degrees. The other rotates 180 degrees. So I think the rotor head that covers the 180 degrees needs to run double the time of the 90 degree one. How can I set this? I've set the sqm for each head, but smart irrigation used the same times for both.
Kind regards,
Sjors
Ver: 3762   Respuesta: 1
Update the irrigation routine according to the updated weather forecast
Luis T
Actualizado 2023-05-24 15:44:31 UTC
Hi there!
I live in Madrid, Spain and use AccuWeather as my weather provider, since NetroWeather does not provide a correct forecast for this area for some reason.
This week we have had heavy rain forecast so Netro will not activate the irrigation system for several days. The problem is that as the day goes by the forecast is changing and Netro's planning is not updated.
It has already been several days in which according to the initial forecast, it was supposed to rain and it did not, so I have had to launch manual irrigations.
Is there any way to force the smart irrigation program to update according to the new weather forecast?
Ver: 4149   Respuesta: 1
Bruno
Actualizado 2023-05-10 22:41:29 UTC
Ver: 4109   Respuesta: 1
Whisperer GPS error
Guido Minciotti
Actualizado 2023-05-10 15:11:55 UTC
Ver: 3963   Respuesta: 1
Alexa
Federico Gietz
Actualizado 2023-04-30 15:28:52 UTC
Ver: 3713   Respuesta: 1
Jim
Actualizado 2023-04-24 17:38:25 UTC
Ver: 4009   Respuesta: 2
Matt Ward
Actualizado 2023-04-14 13:57:11 UTC
Matt
Ver: 4003   Respuesta: 3
