Multiple Pixies?
J Forrest
Actualizado 2021-04-17 03:33:18 UTC
Ver: 4040   Respuesta: 1
How to delete a device
Carles
Actualizado 2021-04-16 12:33:31 UTC
Ver: 4284   Respuesta: 1
Time zone not supported
Havre de Grace
Actualizado 2021-04-15 08:11:30 UTC
I keep getting this error when I try to put my address in Jersey, Channel Islands.
Ver: 3841   Respuesta: 1
Fabio Pellizzoni
Actualizado 2021-04-13 20:10:43 UTC
Do you have any idea why ?
Ver: 4049   Respuesta: 1
Imran Ali
Actualizado 2021-04-12 22:54:05 UTC
Imran Ali
Ver: 4277   Respuesta: 1
Scott Gustafson
Actualizado 2021-04-10 16:04:18 UTC
Scott
Ver: 4383   Respuesta: 1
Moisture Level
Des Mullin
Actualizado 2021-04-09 23:48:09 UTC
Ver: 4329   Respuesta: 1
David Farries
Actualizado 2021-04-07 02:16:14 UTC
Ver: 4148   Respuesta: 1
jjmengibar
Actualizado 2021-04-05 18:16:46 UTC
How can I reset any zone
Ver: 4404   Respuesta: 1
What do the icons mean?
Jim Stichbury
Actualizado 2021-03-31 06:55:06 UTC
Ver: 4163   Respuesta: 1
Server offline
Mirko Paganelli
Actualizado 2021-03-30 16:15:01 UTC
Ver: 4178   Respuesta: 1
Kevin Westling
Actualizado 2021-03-28 06:40:48 UTC
Ver: 4142   Respuesta: 1
When will be Netro Smart available in Europe?
Raúl Vázquez-Noguerol Méndez
Actualizado 2021-03-20 20:38:05 UTC
I’d like to know if Netro Spark will be available in Europe.
Ver: 3995   Respuesta: 1
What does the app show for whisperer?
Growbro
Actualizado 2021-03-17 20:54:48 UTC
I am trying to figure out what the graph shows for the week. It seems like the app shows the average light for the day. Moisture present at midnight each day. And average temperature each day. Is this correct? Or is it maximum temperature for the day?
It would be nice if I could have the graph could show more than just one reading per day. It would also be nice if you could go back and see the more detailed chart for a full day after it has passed. As it is now I can only see the one data point for days that are past.
Finally for the individual days it is a bit annoying switching between am and pm. I wish there was just a graph for each day that looked like the graph for the week/month except that there was a data point for every hour. Definitely more annoying and less useful to have am and pm separate and not be able to see the changes like you can with the graph.
Ver: 4126   Respuesta: 1
Foreca as weather provider
Fran Roman
Actualizado 2021-03-09 21:21:35 UTC
Please add Foreca as weather provider! In Europe is much better than the available options on the app. Metro group is also a good option for your European customers like me.
Ver: 4063   Respuesta: 1
Zone says Loading
Gale
Actualizado 2021-02-24 14:03:11 UTC
After the numerous power outages in Dallas last week, my sprinklers attempted to run this morning.   At its scheduled time, the zone shows "loading" but - no water.   ???
Ver: 3940   Respuesta: 1
Smart Watering Algorithm
Actualizado 2021-02-09 13:52:56 UTC
Ver: 4660   Respuesta: 1
Date Format
Brian Keenan
Actualizado 2021-01-29 09:00:07 UTC
Ver: 4088   Respuesta: 1
Geron R
Actualizado 2021-01-19 23:06:52 UTC
Please advise
Ver: 4279   Respuesta: 1
Metro France cloud down?
Julian Hansen
Actualizado 2020-12-29 01:07:40 UTC
Ver: 4517   Respuesta: 1
