Data records
David Lrx
Actualizado 2024-02-03 12:14:57 UTC
Is it possible to upload data from the app so I can keep record on an externat file for more than a month ?
I would like to keep record for a year long.
David.
Ver: 3886   Respuesta: 1
Manual run times need to be longer and editable while running
Richard
Actualizado 2024-01-19 21:27:13 UTC
Hi Netro,
One frustration I have is that manual run times are important to me but cannot be longer than 1 hour (or programs) and cannot be adjusted while running.
I have Netro connected to a solenoid that controls watering of our small vineyard.
I rarely water in any way other than manual, because I need to control the amount of watering and also use fertigation to feed the vines.
Due to the amount of water required, I need between two to three hours of watering. I also like to adjust as I go, depending on how long the fertigation takes, so the ability to increase time without stopping the watering is also important.
My other solution is to disconnect the wire from Netro and use a Shelly 1 instead, whereby I can turn the watering on and off as I desire.
I would rather just use the Netro app, given that everything is already connected.
It is quite limiting to not allow hours as well as minutes (or to allow more than 60 minutes). amd not to be able to increase (or decrease) the time while the manual run is going.
Ver: 4434   Respuesta: 2
PM Time
Cacho
Actualizado 2024-01-01 15:43:35 UTC
Hello again, i found that i can set night times on the webpage, and it get sets on the app after that.   But if i try from the app i cannot set any night times.
Ver: 4000   Respuesta: 1
Stand alone Whisperer 2 Sensor
suddath
Actualizado 2023-12-30 17:56:29 UTC
We have a Netro Pixie that we have been using to water trees in our backyard.
We purchased two Whisperer 2 sensors to help understand how much to water.
We paired and installed one sensor which is linked to the Pixie.  This sensor works well and reports light, moisture and temperature and appears in the app in the zone watered by our Pixie.
The other sensor installed as "standalone".  This sensor does not show up on our app including in settings.
How do we access this "standalone" sensor or data?
thank you.
Ver: 4015   Respuesta: 1
Pixie & Wisper 2 - How to get them to connect?
Mark Smith
Actualizado 2023-12-08 08:15:08 UTC
I have purchased 3x Wisper 2s and 3x Pixies as well as a Spark. I want to set the watering frequency based on information from the Whispers. In the app, it has a sensor field, but it's not selected. I can't find any instructions on getting them to work together. I opened a ticket with support 2 days ago but no response.
Ver: 4372   Respuesta: 2
Home Assistant integration
Homestead One
Actualizado 2023-12-01 14:54:03 UTC
Hi guys,
Is it possible to integrate nestro smart sprinkler to home assistant?
Thx!
Ver: 4177   Respuesta: 1
Meaning of Pie-Chart Illustration in Sensor Graph
Mark
Actualizado 2023-11-16 08:54:15 UTC
Hi there, Ive noticed that some of the pie-slices in the moisture/temperature/lux graphs from my Whisperer Plant Sensors are heavily coloured (darker) and some are lightly coloured (lighter). Is this supposed to indicate something?
I suspected that maybe the difference in colour reflects upload as either live (or cached), but I double checked and they all have >50% wifi connection strength and report regularly...
Ver: 4247   Respuesta: 1
Actualizado 2023-11-07 06:09:05 UTC
Then you should put Sprite in "paused" mode just in case some one (for example the kids) accidentally starts a manually run from the app. To put Sprite in "paused" mode, you can go to the Home page->"Enabled".
Ver: 9372   Comentario: 1
PROGRAMS. "NOTES" FIELD
Javier NM
Actualizado 2023-11-02 07:49:07 UTC
I am using Netro software with a Sprite-6 controller. After some moths use I am delighted with the system. The tools it provides help me a lot controlling my garden, with good results. Congratulations. Normaly I use three out of my four zones in Smart (advanced) mode, and the fourth one in Smart (Basic).
I would be useful if we could have a field (name it "Notes" or similar) so that we could enter useful information about the use of each individual program (for example, "I reduced frecuency to alternate days after Oct 15th", or other information.
Not having that field causes useful feedback not to be available when managing programs.
Ver: 4297   Respuesta: 1
Sprite 12 Controller Problem
John LaRocca
Actualizado 2023-10-14 01:42:23 UTC
Ver: 3951   Respuesta: 1
Hub with more than 1 timers
Kay Fluhr
Actualizado 2023-10-08 07:46:18 UTC
Dear netro team
I solved the problem.
Ver: 4051   Respuesta: 1
2 zonas funcionando a la vez?
Juan Carlos
Actualizado 2023-09-30 18:53:13 UTC
Ver: 4064   Respuesta: 1
Horario
Conchi Herrero
Actualizado 2023-09-27 13:00:48 UTC
Gracias.
Ver: 3855   Respuesta: 1
Stephen CC
Actualizado 2023-09-19 08:44:03 UTC
Ver: 3991   Respuesta: 1
Addind more than 3 Users?
scgrossengersdorf
Actualizado 2023-08-27 11:07:02 UTC
Hello everyone,
WH
Ver: 3854   Respuesta: 1
TJ Wasik
Actualizado 2023-08-23 18:57:57 UTC
Ver: 3853   Respuesta: 1
Louise Brinkman
Actualizado 2023-08-12 23:01:10 UTC
Ver: 4078   Respuesta: 1
Spark and Sensors
C He
Actualizado 2023-08-10 06:45:57 UTC
Hi all,
Thanks for support!
Ver: 4063   Respuesta: 1
App is not installing
Martin Trevino
Actualizado 2023-08-09 16:40:50 UTC
Ver: 3874   Respuesta: 1
David H
Actualizado 2023-08-04 17:15:09 UTC
Ver: 3975   Respuesta: 1
