Moisture level for lawn
Jan
Actualizado 2020-08-08 08:43:43 UTC
Dear community
Ver: 6113   Respuesta: 1
Metrosideros (Myrtaceae)
Alessandro Raffi
Actualizado 2020-06-03 21:09:16 UTC
Thanks a lot,
Ale
Ver: 7106   Respuesta: 1
Max V
Actualizado 2020-03-27 18:52:10 UTC
Hi everyone!
Ver: 6868   Respuesta: 1
Garden
Steven Carnie
Actualizado 2020-03-26 14:53:02 UTC
Ver: 7104   Respuesta: 1
Riego netro para tepes
Manuel C
Actualizado 2019-10-23 09:36:27 UTC
Hola,
Ver: 6943   Respuesta: 1
morriewayne17@yahoo.com
Morrie Wayne
Actualizado 2019-06-14 13:27:19 UTC
Ver: 7126   Respuesta: 0
St. Augustine
Spencer Vaughn
Actualizado 2019-01-10 03:15:53 UTC
Ver: 7359   Respuesta: 2
Actualizado 2018-12-13 07:48:53 UTC
Burning Bush
Fragrant Sumac
Japanese Yew
California Lilac
Creeping Juniper
Dwarf Forsythia
Snowberry
Siberian
Carpet Cypress
Ver: 8948   Comentario: 1
Actualizado 2018-09-12 07:54:55 UTC
Resources:
Ver: 440268   Comentario: 95
What percentage is ideal for the moisture content for a summer lawn in Southern CA?
Gary Riehl
Actualizado 2018-08-17 18:05:53 UTC
Can you please tell me the ideal percentage for the top soil and sub soil for a Southern CA. lawn in summer?  Does this number change during the other seasons?
Gary
Ver: 7301   Respuesta: 0
Soil type?
John Broadbent
Actualizado 2018-06-16 14:27:36 UTC
Ver: 8220   Respuesta: 2
Actualizado 2018-06-04 12:37:29 UTC
1.Year One
3.After the first week or so
4.Years Two to Three
5.After Year Three
Helpful Tips
Before you water:
Ver: 10677   Comentario: 4
How to Water Trees and Shrubs
Actualizado 2018-06-04 10:07:08 UTC
1.How to Water Shrubs
2.How to Water Trees
Don't wait for the plants to tell you with wilting and leaves dropping off. Then youll just be watering to keep the plants roots alive so it may possible come back later. Inspect the soil. Dig around with your hands, soil probe, garden trowel, or shovel. Youll be able to tell quickly how far down you are actually watering.
Resources
Ver: 10621   Comentario: 3
